Saltar al contenido principal
Sony Action Cam Mini HDR-AZ1 Gasket Replacement
Qué necesitas
  1. Sony Action Cam Mini HDR-AZ1 Gasket Replacement, Gasket Seal: paso 1, imagen 1 de 2 Sony Action Cam Mini HDR-AZ1 Gasket Replacement, Gasket Seal: paso 1, imagen 2 de 2
    • To open the case, slide the tab located on the underside of the case to the “unlock” position.
    • Press in the tabs, that are on the sides of the unlock tab, and pull down. This should cause the lid to open.
    • Remove the lid.
  2. Sony Action Cam Mini HDR-AZ1 Gasket Replacement: paso 2, imagen 1 de 1
    • Using the plastic opening tool, wedge it between the O-Ring and the groove.
    • Move the tool around the ring, prying the gasket from the groove, until it is able to be grabbed.
  3. Sony Action Cam Mini HDR-AZ1 Gasket Replacement: paso 3, imagen 1 de 1
    • Remove the O-Ring from the lid of the case.
Conclusión
To place a new gasket in, follow these steps in reverse order, making sure the gasket is fully pushed back in around its entire perimeter.
Mathieu LaFond
Miembro Desde 10/27/15
425 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 Miembro de UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G7
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 556
