Saltar al contenido principal
Sony Action Cam Mini HDR-AZ1 Battery Door Replacement
Qué necesitas
  1. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: paso 1, imagen 1 de 3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: paso 1, imagen 2 de 3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: paso 1, imagen 3 de 3
    • To access the battery, first make sure the camera is out of the case.
    • Push down on the door lock, located on the rear of the action cam.
    • The door is unlocked if the little yellow square is showing.
    • Pull on the panel door, located on the side opposite the LCD screen, and it should now pop open.
  2. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: paso 2, imagen 1 de 3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: paso 2, imagen 2 de 3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: paso 2, imagen 3 de 3
    • Open the side panel outward to reveal the battery.
    • Be sure not to break the small piece of plastic securing the door to the camera.
    • Use the pull tab to pop the battery out of place.
  3. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery Door: paso 3, imagen 1 de 2 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery Door: paso 3, imagen 2 de 2
    • Remove the circled 4 millimeter black screw adjacent to where the door is attached.
  4. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: paso 4, imagen 1 de 2 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: paso 4, imagen 2 de 2
    • Grab the small black bracket holding the ribbon on which the door is attached and pull it out.
  5. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: paso 5, imagen 1 de 1
    • Pull the door straight back so the attaching ribbon is pulled taught and the door will come right off.
Conclusión
Mathieu LaFond
Miembro Desde 10/27/15
425 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 Miembro de UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G7
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 725
