Saltar al contenido principal
Sony Action Cam HDR-AS15 O-Ring Replacement
Qué necesitas
  1. Sony Action Cam HDR-AS15 O-Ring Replacement, Open the Waterproof Case: paso 1, imagen 1 de 1
    • To open the case, push the yellow "Open" tab located at the bottom of the case.
    • Pull out on the yellow tabs as indicated by the circles in the photo to unlock the lid. This may be a little tricky!
    • Then, remove the lid.
  2. Sony Action Cam HDR-AS15 O-Ring Replacement, Pry the O-ring from the Groove: paso 2, imagen 1 de 1
    • Take the plastic opening tool and wedge it between the O-ring and the groove.
    • Then, pry the O-ring until it is out of the groove.
  3. Sony Action Cam HDR-AS15 O-Ring Replacement, Remove the O-ring: paso 3, imagen 1 de 1
    • Now that the O-ring is out of the groove, remove the O-ring from the lid.
Conclusión
Justin Calean
Miembro Desde 01/09/15
421 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 1-2, Sullivan Winter 2015 Miembro de USF Tampa, Team 1-2, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G2
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 892
