Saltar al contenido principal
Sony Action Cam HDR-AS15 Memory Card Replacement
  1. Sony Action Cam HDR-AS15 Memory Card Replacement, Getting to the Memory Card: paso 1, imagen 1 de 1
    • To access the memory card, push left on the rear of the Action Cam. The rear panel should easily slide to the side.
  2. Sony Action Cam HDR-AS15 Memory Card Replacement, Removing the card: paso 2, imagen 1 de 1
    • After sliding the rear panel to the side, open the door outward to reveal the memory card slot and battery tray.
    • Push in on the back of the memory card with the tip of your finger until you feel a click.
    • Pinch the rear of the memory card that is protruding from the slot and pull on it until the memory card is removed.
Conclusión
Justin Calean
Miembro Desde 01/09/15
421 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 1-2, Sullivan Winter 2015 Miembro de USF Tampa, Team 1-2, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G2
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 680
