Introducción
LCD stands for liquid crystal display, which is a used for displays in different devices. LCD is thinner than the older technology that provides better quality of picture. This guide will successfully show you how to replace the LCD screen of your Sony a6000 camera.
Qué necesitas
Remove the two 1.75mm Phillips #00 screws located on the bottom border of the LCD screen.
Una persona más ha completado esta guía.
2 comentarios
Saw a bran new a6000 screen on eBay. So, I thought it would be easy to replace the scratched screen from my a6000. WOW was I wrong!
First I would say that step 2 is very hard to accomplish without stripping the screw. You need to pry the screen to get to an angle where it's doable. On my first attempt I striped the screw. I tried it on a second a6000 and successfully could remove the screw.
As it wasn't evident to me at first, I think it's important to specify that on step 7 you need to lift carefully the little black flap on the zero insertion force cable connector to unlock it. It's weak and I feel like it would be very prone to breaking.
What is NOT showed on this guide is what comes AFTER step 8! The screen is actually in a plastic frame That does not ship with the replacement screen and this frame is glued! So unless you have plastic glue and are able to unglue it first, you should NOT attempt this repair.
Consequently, I reassembled everything and have resigned myself to living with the scratchs.
