Introducción
This guide will tell you how to replace the flash assembly of the a6000 camera if it breaks or gets damaged.
Qué necesitas
Position the camera with the flash assembly facing upwards.
Locate the flash assembly.
4 personas más completaron esta guía.
3 comentarios
Anyone know where to get the flash? My daughter’s has the “won’t stay closed” problem so common to the a-series and I need to replace it.
Thanks, good guide but please update it according to Jürgens comments or there is a big risk people will break their top panel.
David: I got the flash unit from AliExpress, but you can find it on Ebay as well.
Thanks for the guide! I had to open additional 2 more screws inside the battery compartment. and only had to remove 2 bottom screws on Step 8 (instead of 3). Replaced the flash unit without any issue. Thank you!
