Introducción
Caution: Unplug the Sonos Playbase before starting the disassembly to avoid electrocuting yourself.
Replacement of a main speaker requires iFixit prying tools and screwdrivers. Optionally, a heat source helps to more easily remove adhesive while opening up your device.
Qué necesitas
Herramienta utilizada en este paso:Pro Tech Toolkit$59.96
Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
Disconnect the main speaker array from the main board, by pinching and and pulling the tab out.
