Introducción
If your tweeter speaker sounds muffled or disstorted, then you can properly remove it by using the correct technique without further damaging it.
Qué necesitas
Use the metal spudger to pry open the front grill. Little force will be needed to wedge the metal spudger into the crevice.
After the grill has been loosened on all edges. Use your fingers as a wedge and gently pull the grill off the speaker. This will reveal the front speaker panel.
Use a pointed metal spudger to remove the rubber plugs covering the screws in the bottom left and right corners of the speaker panel.
Insert the spudger against the side of the rubber plug and the speaker panel while leveraging upward.
Remove the eight 12 mm Phillips #1 screws bordering the front speaker panel.
Herramienta utilizada en este paso:Tweezers$4.99
With a #1 Phillips-head screwdriver, remove the eight 12mm screws on the bottom panel.
We have marked the original placement of the warranty stickers in orange. To remove use a pair of tweezers to grip onto the sticker and pull with a gentle upward motion
After you unclip the connecters, locate the tweeter speaker.
Place your hand around the tweeter speaker and locate the area your going to start removing.
Una persona más ha completado esta guía.
