Saltar al contenido principal
Sonos Play 5 Tweeter Replacement
Qué necesitas
  1. Sonos Play 5 Tweeter  Replacement, Front Panel Assembly: paso 1, imagen 1 de 1
    • Disconnect any power to the speaker and wait a few minutes for the capacitors to fully discharge.
    • Flip the speaker upside down.
    • There may be a rubber foot covering the bottom screws (not included in picture). Remove this by pulling up from one of the corners using a spudger.
  2. Sonos Play 5 Tweeter  Replacement: paso 2, imagen 1 de 2 Sonos Play 5 Tweeter  Replacement: paso 2, imagen 2 de 2
    • Remove eight 10mm Phillips #2 screws
    • Remove the bottom panel by pulling upwards.
    • Be very gentle with the ends of the three antennas. They are very fragile.
  3. Sonos Play 5 Tweeter  Replacement: paso 3, imagen 1 de 3 Sonos Play 5 Tweeter  Replacement: paso 3, imagen 2 de 3 Sonos Play 5 Tweeter  Replacement: paso 3, imagen 3 de 3
    • Flip the device so that the grille is facing up.
    • Locate the line on the right side of the speaker where the grill and the plastic meet, and place your plastic opening tool in the gap.
    • Run the spudger along the gap, loosening the grille from the plastic. Repeat this process on the left side as well.
    • Gently pull up on the grille, removing it from the front panel.
  4. Sonos Play 5 Tweeter  Replacement: paso 4, imagen 1 de 1
    • Remove the six 8mm Phillips #2 screws.
    • Remove the two 10mm Phillips #2 screws.
  5. Sonos Play 5 Tweeter  Replacement: paso 5, imagen 1 de 2 Sonos Play 5 Tweeter  Replacement: paso 5, imagen 2 de 2
    • Locate the line on the right side where the front panel and back panel meet. Place a plastic opening tool in the gap, and run it along the gap. Repeat this on the left side.
    • Use the opening tool to lift the front plate. If a plastic tool is not providing enough leverage, use a metal opening tool.
    • Gently pull up on the face plate to ensure it has been detached from the enclosure.
    • When pulling on the face plate be cautious because it is still connected by wires on the back of the plate.
  6. Sonos Play 5 Tweeter  Replacement: paso 6, imagen 1 de 3 Sonos Play 5 Tweeter  Replacement: paso 6, imagen 2 de 3 Sonos Play 5 Tweeter  Replacement: paso 6, imagen 3 de 3
    • Lift up the front panel, forming a 90 degree angle with the back panel. Locate the locate ten pin connector shown. This is the wire that connects the front panel to back panel.
    • Press down on the small tab located on the connector. With the tab firmly pressed down, pull the connector out from its socket.
    • The faceplate assembly is now fully detached from the rest of the speaker.
  7. Sonos Play 5 Tweeter  Replacement, Tweeter: paso 7, imagen 1 de 3 Sonos Play 5 Tweeter  Replacement, Tweeter: paso 7, imagen 2 de 3 Sonos Play 5 Tweeter  Replacement, Tweeter: paso 7, imagen 3 de 3
    • Locate the Tweeters on the back of the front panel assembly.
  8. Sonos Play 5 Tweeter  Replacement: paso 8, imagen 1 de 2 Sonos Play 5 Tweeter  Replacement: paso 8, imagen 2 de 2
    • Remove wires connected to the Tweeter.
  9. Sonos Play 5 Tweeter  Replacement: paso 9, imagen 1 de 2 Sonos Play 5 Tweeter  Replacement: paso 9, imagen 2 de 2
    • Lightly push down on the tweeter and then twist it out gently counterclockwise.
    • Gently lift the tweeter out.
Conclusión
Una persona más ha completado esta guía.
Warren Girouard
Miembro Desde 02/20/17
309 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S3-G6, Sullivan Spring 2017 Miembro de USF Tampa, Team S3-G6, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G6
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 27
Todo El Tiempo: 3,285
