Saltar al contenido principal
Sonos Play 3 Speaker Grille Replacement
Qué necesitas
  1. Sonos Play 3 Speaker Grille Replacement, Speaker Grille: paso 1, imagen 1 de 2 Sonos Play 3 Speaker Grille Replacement, Speaker Grille: paso 1, imagen 2 de 2
    • Insert a spudger along the edge of the screen and gently use it to pull the screen away from the casing. Slide the spudger along the length of the grill to detach all the clips holding it in place.
  2. Sonos Play 3 Speaker Grille Replacement: paso 2, imagen 1 de 1
    • Gently pull the screen away from the body of the speaker, revealing the tweeter and two mid-range drivers behind it.
    • There may be a kind of black sticky adhesive holding the screen clips to the rest of the body; however, it was previously removed on our model.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 25-6, Maness Spring 2016 Miembro de Cal Poly, Team 25-6, Maness Spring 2016
CPSU-MANESS-S16S25G6
4 Miembros
14 Guías creadas
2 comentarios
According to Sonos the grille is NOT removable. Looks like the adhesive mentioned above is there for a purpose. Shame really.
Alan Mackay - Contestar
I've had my sonos 3 outside for three years, under cover though. It started to sound awful a couple of weeks ago. I thought they would try to remove the grille, but according to Sonos there was no way to remove the grille, it was a fixed assembly.
But yesterday I put more effort into googling, and found this page. I understand that it sounded bad, there was dirt, dust and other debris in it when I finally got rid of the grille, now I just have to listen to it, because it was late yesterday and I have to pay attention to the neighbors, so I could not find out at such a low volume if it helped, but I think so. You saved me from going and buying one or two Sonos 1 play, as my son suggested. We will have to wait and see until the neighbors around have woken up. I have high hopes that it works, Thanks for a tip on the unopening Sonos 3, shame on the one who gives up (a Swedish
proverb).
Thanks
/ Anders
anders wargen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 41
Todo El Tiempo: 6,663
