Saltar al contenido principal
Sonos Play 1 Tweeter Speaker Replacement
Qué necesitas
  1. Sonos Play 1 Tweeter Speaker Replacement, Exterior Screen: paso 1, imagen 1 de 2 Sonos Play 1 Tweeter Speaker Replacement, Exterior Screen: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
    • Once you pry open one end, use precision tweezers to remove rubber footing.
  2. Sonos Play 1 Tweeter Speaker Replacement: paso 2, imagen 1 de 2 Sonos Play 1 Tweeter Speaker Replacement: paso 2, imagen 2 de 2
    • Using a metal spudger, pry open a corner of the adhesive tape.
    • Use precision tweezers to remove the adhesive tape.
  3. Sonos Play 1 Tweeter Speaker Replacement: paso 3, imagen 1 de 2 Sonos Play 1 Tweeter Speaker Replacement: paso 3, imagen 2 de 2
    • Remove the four 10 mm Torx security #10 screws that hold the base together.
    • Remove the base by lifting it vertically away from the bulk of the device.
  4. Sonos Play 1 Tweeter Speaker Replacement: paso 4, imagen 1 de 2 Sonos Play 1 Tweeter Speaker Replacement: paso 4, imagen 2 de 2
    • Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
    • Using precision tweezers, remove the metal bracket.
  5. Sonos Play 1 Tweeter Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the exterior screen by lifting it away from the bulk of the device.
  6. Sonos Play 1 Tweeter Speaker Replacement, Sonos Play 1 Top Cover Disassembly: paso 6, imagen 1 de 1
    • Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
  7. Sonos Play 1 Tweeter Speaker Replacement: paso 7, imagen 1 de 3 Sonos Play 1 Tweeter Speaker Replacement: paso 7, imagen 2 de 3 Sonos Play 1 Tweeter Speaker Replacement: paso 7, imagen 3 de 3
    • Using a plastic opening tool, pry open the top cap containing the power and volume button.
    • Vertically remove the top cap.
    • Be sure to not jerk the top cap when removing , as to not damage the cable linking the switchboard to the motherboard.
  8. Sonos Play 1 Tweeter Speaker Replacement: paso 8, imagen 1 de 2 Sonos Play 1 Tweeter Speaker Replacement: paso 8, imagen 2 de 2
    • Using a plastic opening tool, pry open the circuit flap.
    • Once flap is loosened, use your hand to remove the circuit wire.
  9. Sonos Play 1 Tweeter Speaker Replacement, Disassembling Sonos Play 1 Rear Housing Cover: paso 9, imagen 1 de 2 Sonos Play 1 Tweeter Speaker Replacement, Disassembling Sonos Play 1 Rear Housing Cover: paso 9, imagen 2 de 2
    • Using a plastic opening tool, remove the grey tape from both sides of the device.
  10. Sonos Play 1 Tweeter Speaker Replacement: paso 10, imagen 1 de 2 Sonos Play 1 Tweeter Speaker Replacement: paso 10, imagen 2 de 2
    • Remove the six 9 mm Torx #9 screws.
    • Using a plastic opening tool, detach the rear housing cover from the housing.
    • Try not to jerk the rear housing cover, as its wires are still connected to delicate electronics.
  11. Sonos Play 1 Tweeter Speaker Replacement: paso 11, imagen 1 de 2 Sonos Play 1 Tweeter Speaker Replacement: paso 11, imagen 2 de 2
    Comprar
    • Using tweezers, grip the connector fixed to the motherboard's audio cable.
    • While pulling on the connector, detach the cable by pressing the connectors release.
  12. Sonos Play 1 Tweeter Speaker Replacement: paso 12, imagen 1 de 1
    • Using your fingers, grip the connector fixed to the motherboards power cable and detach it.
    • You will now be able to remove the rear housing cover.
  13. Sonos Play 1 Tweeter Speaker Replacement, Mid-Woofer speaker: paso 13, imagen 1 de 1
    • Remove the two 9mm Torx #9 screws fastening the power cable to the housing.
    • Remove the power cable.
  14. Sonos Play 1 Tweeter Speaker Replacement: paso 14, imagen 1 de 1
    • Using a metal spudger, press the release located in the center of the connector .
    • While pressing the release pull on the connector detaching it from the speaker.
    • Do this for both connections.
  15. Sonos Play 1 Tweeter Speaker Replacement: paso 15, imagen 1 de 2 Sonos Play 1 Tweeter Speaker Replacement: paso 15, imagen 2 de 2
    • Using the Torx T20 bit remove the four 13 mm screws fastening the speaker to the housing.
    • Remove the speaker by lifting it up towards the top of the housing and out at an angle.
  16. Sonos Play 1 Tweeter Speaker Replacement, Tweeter Speaker: paso 16, imagen 1 de 2 Sonos Play 1 Tweeter Speaker Replacement, Tweeter Speaker: paso 16, imagen 2 de 2
    • Using a metal spudger, press down on the clips that lock the input wires to the amplifier.
    • Once unlocked, pull back on the wires to remove them.
  17. Sonos Play 1 Tweeter Speaker Replacement: paso 17, imagen 1 de 2 Sonos Play 1 Tweeter Speaker Replacement: paso 17, imagen 2 de 2
    • Using a screwdriver, remove the four 10 mm Torx Security #10 screws.
    • Using your fingers, remove the tweeter from the front of the housing.
Conclusión
2 personas más completaron esta guía.
Gregory Klein
Miembro Desde 08/27/15
626 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 8-4, Eyestone Fall 2015 Miembro de USF Tampa, Team 8-4, Eyestone Fall 2015
USFT-EYESTONE-F15S8G4
4 Miembros
16 Guías creadas
3 comentarios
Can anybody recommend a source for a replacement tweeter speaker with comparable specs? Unless I missed something, this article doesn't address that, and that's kind of an important piece of the puzzle.
John Martinez - Contestar
You can get them from Aliexpress for about 10€.
Stanton Attree - Contestar
How do I look for the speaker replacement, what characteristics should I indicate because I can't find it, greetings
Gerardo Arguedas - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 32
Todo El Tiempo: 8,882
