Introducción
This is a prerequisite for the other Sonos Play 1 guides.
Qué necesitas
Herramienta utilizada en este paso:Tweezers$4.99
Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
Once you pry open one end, use precision tweezers to remove rubber footing.
Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
Casi Terminas!
Conclusión
