Saltar al contenido principal
Sonos Play 1 Mid-Woofer speaker Replacement
Qué necesitas
  1. Sonos Play 1 Mid-Woofer speaker Replacement, Exterior Screen: paso 1, imagen 1 de 2 Sonos Play 1 Mid-Woofer speaker Replacement, Exterior Screen: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
    • Once you pry open one end, use precision tweezers to remove rubber footing.
  2. Sonos Play 1 Mid-Woofer speaker Replacement: paso 2, imagen 1 de 2 Sonos Play 1 Mid-Woofer speaker Replacement: paso 2, imagen 2 de 2
    • Using a metal spudger, pry open a corner of the adhesive tape.
    • Use precision tweezers to remove the adhesive tape.
  3. Sonos Play 1 Mid-Woofer speaker Replacement: paso 3, imagen 1 de 2 Sonos Play 1 Mid-Woofer speaker Replacement: paso 3, imagen 2 de 2
    • Remove the four 10 mm Torx security #10 screws that hold the base together.
    • Remove the base by lifting it vertically away from the bulk of the device.
  4. Sonos Play 1 Mid-Woofer speaker Replacement: paso 4, imagen 1 de 2 Sonos Play 1 Mid-Woofer speaker Replacement: paso 4, imagen 2 de 2
    • Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
    • Using precision tweezers, remove the metal bracket.
  5. Sonos Play 1 Mid-Woofer speaker Replacement: paso 5, imagen 1 de 1
    • Remove the exterior screen by lifting it away from the bulk of the device.
  6. Sonos Play 1 Mid-Woofer speaker Replacement, Sonos Play 1 Top Cover Disassembly: paso 6, imagen 1 de 1
    • Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
  7. Sonos Play 1 Mid-Woofer speaker Replacement: paso 7, imagen 1 de 3 Sonos Play 1 Mid-Woofer speaker Replacement: paso 7, imagen 2 de 3 Sonos Play 1 Mid-Woofer speaker Replacement: paso 7, imagen 3 de 3
    • Using a plastic opening tool, pry open the top cap containing the power and volume button.
    • Vertically remove the top cap.
    • Be sure to not jerk the top cap when removing , as to not damage the cable linking the switchboard to the motherboard.
  8. Sonos Play 1 Mid-Woofer speaker Replacement: paso 8, imagen 1 de 2 Sonos Play 1 Mid-Woofer speaker Replacement: paso 8, imagen 2 de 2
    • Using a plastic opening tool, pry open the circuit flap.
    • Once flap is loosened, use your hand to remove the circuit wire.
  9. Sonos Play 1 Mid-Woofer speaker Replacement, Disassembling Sonos Play 1 Rear Housing Cover: paso 9, imagen 1 de 2 Sonos Play 1 Mid-Woofer speaker Replacement, Disassembling Sonos Play 1 Rear Housing Cover: paso 9, imagen 2 de 2
    • Using a plastic opening tool, remove the grey tape from both sides of the device.
  10. Sonos Play 1 Mid-Woofer speaker Replacement: paso 10, imagen 1 de 2 Sonos Play 1 Mid-Woofer speaker Replacement: paso 10, imagen 2 de 2
    • Remove the six 9 mm Torx #9 screws.
    • Using a plastic opening tool, detach the rear housing cover from the housing.
    • Try not to jerk the rear housing cover, as its wires are still connected to delicate electronics.
  11. Sonos Play 1 Mid-Woofer speaker Replacement: paso 11, imagen 1 de 2 Sonos Play 1 Mid-Woofer speaker Replacement: paso 11, imagen 2 de 2
    • Using tweezers, grip the connector fixed to the motherboard's audio cable.
    • While pulling on the connector, detach the cable by pressing the connectors release.
  12. Sonos Play 1 Mid-Woofer speaker Replacement: paso 12, imagen 1 de 1
    • Using your fingers, grip the connector fixed to the motherboards power cable and detach it.
    • You will now be able to remove the rear housing cover.
  13. Sonos Play 1 Mid-Woofer speaker Replacement, Mid-Woofer speaker: paso 13, imagen 1 de 1
    • Remove the two 9mm Torx #9 screws fastening the power cable to the housing.
    • Remove the power cable.
  14. Sonos Play 1 Mid-Woofer speaker Replacement: paso 14, imagen 1 de 1
    • Using a metal spudger, press the release located in the center of the connector .
    • While pressing the release pull on the connector detaching it from the speaker.
    • Do this for both connections.
  15. Sonos Play 1 Mid-Woofer speaker Replacement: paso 15, imagen 1 de 2 Sonos Play 1 Mid-Woofer speaker Replacement: paso 15, imagen 2 de 2
    • Using the Torx T20 bit remove the four 13 mm screws fastening the speaker to the housing.
    • Remove the speaker by lifting it up towards the top of the housing and out at an angle.
Conclusión
18 personas más completaron esta guía.
Gregory Klein
Miembro Desde 08/27/15
692 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 8-4, Eyestone Fall 2015 Miembro de USF Tampa, Team 8-4, Eyestone Fall 2015
USFT-EYESTONE-F15S8G4
Miembros de 4
16 Guías creadas
42 comentarios
Step 12 omits the connection to the Wi-Fi board. It's attached behind the hand in the picture and removing two T7 screws lets it slide out.
Maurice Leacock - Contestar
Where can i buy a new mid-woofer speaker?
Krister Skaathun - Contestar
Hi you have notice for midWoofer? asmaccocell@gmail.com
asmacco -
Nice guide. But without a matching replacement speaker, or at least specifications, it is useless. Even worse: without opening my Play:1 would be accepted at Sonos support :(
Bebblebrox99 - Contestar
true true ))
totally pointless
whats the specs to replace the subwoofer
montpc74 -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 29
Ultimos 30 días: 155
Todo El Tiempo: 38,187
