Saltar al contenido principal
Sonos One Protective Cover Replacement
Qué necesitas
  1. Sonos One Protective Cover Replacement, Protective Cover: paso 1, imagen 1 de 3 Sonos One Protective Cover Replacement, Protective Cover: paso 1, imagen 2 de 3 Sonos One Protective Cover Replacement, Protective Cover: paso 1, imagen 3 de 3
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Protective Cover Replacement: paso 2, imagen 1 de 3 Sonos One Protective Cover Replacement: paso 2, imagen 2 de 3 Sonos One Protective Cover Replacement: paso 2, imagen 3 de 3
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  3. Sonos One Protective Cover Replacement: paso 3, imagen 1 de 2 Sonos One Protective Cover Replacement: paso 3, imagen 2 de 2
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Protective Cover Replacement: paso 4, imagen 1 de 3 Sonos One Protective Cover Replacement: paso 4, imagen 2 de 3 Sonos One Protective Cover Replacement: paso 4, imagen 3 de 3
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Protective Cover Replacement: paso 5, imagen 1 de 2 Sonos One Protective Cover Replacement: paso 5, imagen 2 de 2
    • Slide the protective cover upwards to remove.
Conclusión
4 personas más completaron esta guía.
Marcus Glowa
Miembro Desde 02/14/18
965 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S2-G1, Nance Spring 2018 Miembro de USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Miembros
6 Guías creadas
Un comentario
Well done! I would add a little bit about how much adhesive there is underneath the rubber feet as well as the screw cover.
Joshua Pinter - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 56
Todo El Tiempo: 4,821
