Saltar al contenido principal
Sonos One Power Adapter Replacement
Qué necesitas
  1. Sonos One Power Adapter Replacement, Protective Cover: paso 1, imagen 1 de 3 Sonos One Power Adapter Replacement, Protective Cover: paso 1, imagen 2 de 3 Sonos One Power Adapter Replacement, Protective Cover: paso 1, imagen 3 de 3
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Power Adapter Replacement: paso 2, imagen 1 de 3 Sonos One Power Adapter Replacement: paso 2, imagen 2 de 3 Sonos One Power Adapter Replacement: paso 2, imagen 3 de 3
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  3. Sonos One Power Adapter Replacement: paso 3, imagen 1 de 2 Sonos One Power Adapter Replacement: paso 3, imagen 2 de 2
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Power Adapter Replacement: paso 4, imagen 1 de 3 Sonos One Power Adapter Replacement: paso 4, imagen 2 de 3 Sonos One Power Adapter Replacement: paso 4, imagen 3 de 3
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Power Adapter Replacement: paso 5, imagen 1 de 2 Sonos One Power Adapter Replacement: paso 5, imagen 2 de 2
    • Slide the protective cover upwards to remove.
  6. Sonos One Power Adapter Replacement, Control Panel & Microphone: paso 6, imagen 1 de 3 Sonos One Power Adapter Replacement, Control Panel & Microphone: paso 6, imagen 2 de 3 Sonos One Power Adapter Replacement, Control Panel & Microphone: paso 6, imagen 3 de 3
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
  7. Sonos One Power Adapter Replacement: paso 7, imagen 1 de 2 Sonos One Power Adapter Replacement: paso 7, imagen 2 de 2
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
  8. Sonos One Power Adapter Replacement: paso 8, imagen 1 de 3 Sonos One Power Adapter Replacement: paso 8, imagen 2 de 3 Sonos One Power Adapter Replacement: paso 8, imagen 3 de 3
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
  9. Sonos One Power Adapter Replacement: paso 9, imagen 1 de 2 Sonos One Power Adapter Replacement: paso 9, imagen 2 de 2
    • Pull the control panel away from the speaker to separate.
  10. Sonos One Power Adapter Replacement, Power Adapter Receptacle: paso 10, imagen 1 de 3 Sonos One Power Adapter Replacement, Power Adapter Receptacle: paso 10, imagen 2 de 3 Sonos One Power Adapter Replacement, Power Adapter Receptacle: paso 10, imagen 3 de 3
    • Remove the six 9mm Torx T8 screws from the motherboard panel.
  11. Sonos One Power Adapter Replacement: paso 11, imagen 1 de 2 Sonos One Power Adapter Replacement: paso 11, imagen 2 de 2
    • Using a plastic opening tool, separate the motherboard from the speaker.
  12. Sonos One Power Adapter Replacement: paso 12, imagen 1 de 3 Sonos One Power Adapter Replacement: paso 12, imagen 2 de 3 Sonos One Power Adapter Replacement: paso 12, imagen 3 de 3
    • Using your thumb, disconnect the speaker cable from the motherboard.
  13. Sonos One Power Adapter Replacement: paso 13, imagen 1 de 3 Sonos One Power Adapter Replacement: paso 13, imagen 2 de 3 Sonos One Power Adapter Replacement: paso 13, imagen 3 de 3
    • Disconnect the power adapter plug from the motherboard using your thumb.
  14. Sonos One Power Adapter Replacement: paso 14, imagen 1 de 3 Sonos One Power Adapter Replacement: paso 14, imagen 2 de 3 Sonos One Power Adapter Replacement: paso 14, imagen 3 de 3
    • Using the pointed end of the spudger, disconnect the red, green, and yellow cables connecting the WiFi transmitter/receiver.
  15. Sonos One Power Adapter Replacement: paso 15, imagen 1 de 2 Sonos One Power Adapter Replacement: paso 15, imagen 2 de 2
    • Remove the motherboard panel from the speaker housing.
  16. Sonos One Power Adapter Replacement: paso 16, imagen 1 de 3 Sonos One Power Adapter Replacement: paso 16, imagen 2 de 3 Sonos One Power Adapter Replacement: paso 16, imagen 3 de 3
    • The woofer is highly magnetic, making removal of the metal screws sometimes difficult.
    • Remove the two 9mm Torx T8 screws from the power adapter plug.
    • Remove the power adapter receptacle from its housing slot.
Conclusión
7 personas más completaron esta guía.
Marcus Glowa
Miembro Desde 02/14/18
965 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S2-G1, Nance Spring 2018 Miembro de USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 18
Ultimos 30 días: 92
Todo El Tiempo: 7,440
