Saltar al contenido principal
Sonos Connect Top Motherboard Replacement
Qué necesitas
  1. Sonos Connect Top Motherboard Replacement, WIFI Card: paso 1, imagen 1 de 3 Sonos Connect Top Motherboard Replacement, WIFI Card: paso 1, imagen 2 de 3 Sonos Connect Top Motherboard Replacement, WIFI Card: paso 1, imagen 3 de 3
    • Start by using a spudger or plastic opening tool to remove the bottom cover.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Once enough of the glue is removed, peel the cover off by hand,
  2. Sonos Connect Top Motherboard Replacement: paso 2, imagen 1 de 3 Sonos Connect Top Motherboard Replacement: paso 2, imagen 2 de 3 Sonos Connect Top Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove the four 7.5mm length Philips head screws under the rubber cover.
  3. Sonos Connect Top Motherboard Replacement: paso 3, imagen 1 de 3 Sonos Connect Top Motherboard Replacement: paso 3, imagen 2 de 3 Sonos Connect Top Motherboard Replacement: paso 3, imagen 3 de 3
    • Use a nylon spudger to unsnap the bottom from the sides.
    • Pry until the remaining three points are unsnapped.
    • Once unsnapped, lift the cover.
  4. Sonos Connect Top Motherboard Replacement: paso 4, imagen 1 de 2 Sonos Connect Top Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the connection for the front buttons to fully remove the cover.
  5. Sonos Connect Top Motherboard Replacement: paso 5, imagen 1 de 2 Sonos Connect Top Motherboard Replacement: paso 5, imagen 2 de 2
    • Use a plastic opening tool or spudger to remove the adhesive covering the the WIFI connectors.
    • Gently pull the wires at the connection point to disconnect them from the motherboard.
  6. Sonos Connect Top Motherboard Replacement: paso 6, imagen 1 de 2 Sonos Connect Top Motherboard Replacement: paso 6, imagen 2 de 2
    • Remove the two pieces of glue holding the WIFI card in place.
  7. Sonos Connect Top Motherboard Replacement: paso 7, imagen 1 de 3 Sonos Connect Top Motherboard Replacement: paso 7, imagen 2 de 3 Sonos Connect Top Motherboard Replacement: paso 7, imagen 3 de 3
    • Scrape the glued pad underneath the WIFI card to seperate the card from the board.
    • Push apart the two clips holding the WIFI card in the connection.
    • Pull the WIFI card out of the connection.
    • When putting the new WIFI card in, put the card in the connector first, then push downward until it clicks.
  8. Sonos Connect Top Motherboard Replacement, Top Motherboard: paso 8, imagen 1 de 1
    • Remove the 7mm length Phillips screw holding the board in place.
  9. Sonos Connect Top Motherboard Replacement: paso 9, imagen 1 de 2 Sonos Connect Top Motherboard Replacement: paso 9, imagen 2 de 2
    • Flip the board over to access the Molex Cable.
  10. Sonos Connect Top Motherboard Replacement: paso 10, imagen 1 de 1
    • Disconnect the Molex Cable from the top motherboard.
Conclusión
2 personas más completaron esta guía.
Clark Snyder
Miembro Desde 01/21/16
483 Reputación
4 Guías creadas
Equipo
IUPUI, Team 3-2, Baechle Spring 2016 Miembro de IUPUI, Team 3-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G2
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 1,972
