Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Herramientas
Partes
  1. Remove the rubber pads and unscrew
    • Remove the rubber pads and unscrew
  2. Take care not to damage the wires of the Wi-Fi antennas which are very bothersome.
    • Take care not to damage the wires of the Wi-Fi antennas which are very bothersome.
  3. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  4. By using a screwdriver inserted through each of the 8 peripheral slots, you can access the clips of the top cover. By using a screwdriver inserted through each of the 8 peripheral slots, you can access the clips of the top cover.
    • By using a screwdriver inserted through each of the 8 peripheral slots, you can access the clips of the top cover.
  5. Continue unscrewing (there is a screw under the seal).
    • Continue unscrewing (there is a screw under the seal).
  6. It's a soldered fuse. You will need to desolder it from the back in order to replace it.
    • It's a soldered fuse. You will need to desolder it from the back in order to replace it.
  7. About 1$
    • About 1$
    • 250V 5A T fuse (time delay).
Conclusión
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
YvesG
Miembro Desde 04/06/18
11 Reputación
1 Guía escrita
Bravo
Ce tuto peux rendre service a des consommateurs abusés par la sociète Sonos .
Merci
bruno vinay - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 247
