Saltar al contenido principal
Sonos Bridge Ethernet Port Replacement
Qué necesitas
  1. Sonos Bridge Ethernet Port Replacement, Ethernet Port: paso 1, imagen 1 de 1
    • The rubber bottom is glued on, meaning it can be easily pried off using the metal spudger.
    • You may have to pry from multiple locations.
  2. Sonos Bridge Ethernet Port Replacement: paso 2, imagen 1 de 3 Sonos Bridge Ethernet Port Replacement: paso 2, imagen 2 de 3 Sonos Bridge Ethernet Port Replacement: paso 2, imagen 3 de 3
    • There is one screw in each corner of the base for a total of four screws.
    • Remove each screw using the Phillips 1 screwdriver.
    • The four screws are each 0.9 cm long.
    • The screws are small, so be careful to not lose them.
  3. Sonos Bridge Ethernet Port Replacement: paso 3, imagen 1 de 2 Sonos Bridge Ethernet Port Replacement: paso 3, imagen 2 de 2
    • Use the metal spudger to pry out the plastic bottom.
    • Alternatively, the casing can be lightly tapped on a table (base down) to drop the bottom out of the casing.
  4. Sonos Bridge Ethernet Port Replacement: paso 4, imagen 1 de 2 Sonos Bridge Ethernet Port Replacement: paso 4, imagen 2 de 2
    • Pry out the circuit board.
    • Place the metal spudger under the board on the side opposite the two ports.
    • The board can then be easily wiggled out of the casing.
    • This should NOT require significant force.
  5. Sonos Bridge Ethernet Port Replacement: paso 5, imagen 1 de 3 Sonos Bridge Ethernet Port Replacement: paso 5, imagen 2 de 3 Sonos Bridge Ethernet Port Replacement: paso 5, imagen 3 de 3
    • Locate the Ethernet port on the circuit board, shown with the red box in the first image.
    • Locate the solders attached to the Ethernet port.
    • Use the soldering iron to undo the solders.
    • Carefully remove the Ethernet port by using the metal spudger and squeezing the black clips.
Conclusión
Brian Strader
Miembro Desde 11/07/17
201 Reputación
2 Guías creadas
Equipo
IUPUI, Team S3-G4, Harley Fall 2017 Miembro de IUPUI, Team S3-G4, Harley Fall 2017
IUPUI-HARLEY-F17S3G4
3 Miembros
2 Guías creadas
Un comentario
Hi could you tell me how to fix sonos zp100 bridge player internet port also where to get parts thanks
imranp7 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 24
Todo El Tiempo: 1,741
