Saltar al contenido principal
Solving slow moving ceiling fan with remote control
Qué necesitas
Resumen del Video
  1. Solving slow moving ceiling fan with remote control, Capacitor (depends on brand): paso 1, imagen 1 de 3 Solving slow moving ceiling fan with remote control, Capacitor (depends on brand): paso 1, imagen 2 de 3 Solving slow moving ceiling fan with remote control, Capacitor (depends on brand): paso 1, imagen 3 de 3
    • Specification for capacitor are sometimes printed at the size. This brand uses 0.82uF 275V capacitor. Specification varies with brand.
  2. Solving slow moving ceiling fan with remote control: paso 2, imagen 1 de 1
    • It will be so much easier if the board can be clamp down using the board repair clamp to hold the board while desoldering the correct capacitor.
  3. Solving slow moving ceiling fan with remote control: paso 3, imagen 1 de 1
    • Simple suction pump required to remove the molten fuse.
  4. Solving slow moving ceiling fan with remote control: paso 4, imagen 1 de 1
    • Cut off the excess length using a tiny cutter after a new capacitor is being soldered onto the board.
  5. Solving slow moving ceiling fan with remote control: paso 5, imagen 1 de 1
    • Test the fan if it is moving at maximum speed after the capacitor is being replaced before assembling it.
Conclusión
Test the board if working before reassembly the circuit board back into the ceiling fan.
SengChoy Liew
Miembro Desde 03/12/12
969 Reputación
3 Guías creadas
1Guía Comentario
Not worth it, going to trash it & buy simple fan.
Joe W - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 56
Todo El Tiempo: 4,438
