Introducción
This guide covers how to disassemble the solar panel portion of the Solio Xcellerator and Hub Battery Pack Solar Panel for both a complete removal and a replacement of the solar panel in a step-by-step instruction.
Qué necesitas
Herramienta utilizada en este paso:iFixit Opening Picks (Set of 6)$4.99
Keep on sliding iFixit Opening Picks into the edges of the panel without removing the ones already in place. The panel may reattach if the clips are not completely broken.
Herramienta utilizada en este paso:Phillips #00 Screwdriver$5.49
Take the Phillips # 00 Screwdriver and begin to unscrew the two black screws.
Herramienta utilizada en este paso:Flush Cutter$29.99
Place the solar panel on a surface that you can solder on.
Cut the two wires connecting the circuit board to the solar panel at the base near the solar panel by using wire cutters.
Take out the Soldering Station. With the new solar panel, solder each lead back to the circuit board, ensuring the positive and negative leads match up correctly as displayed in the photo. Refer to the Repairing Soldered Connection Guide.
Put the device back together following the same guide in reverse order.
When you reach step 8, apply your Evo-Stick Super Glue along the edges of the plastic panel.
Press the panel back into place on the device. Let it sit and dry for 24 hours before use.
Enjoy your working device!
For reassembly of the device, please follow the instructions in the reverse order.
4 personas más completaron esta guía.
