Saltar al contenido principal
Solio Rocsta LED Replacement
Qué necesitas
  1. Solio Rocsta LED Replacement, Solio Rocsta Top Cover Disassembly: paso 1, imagen 1 de 2 Solio Rocsta LED Replacement, Solio Rocsta Top Cover Disassembly: paso 1, imagen 2 de 2
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
  2. Solio Rocsta LED Replacement: paso 2, imagen 1 de 2 Solio Rocsta LED Replacement: paso 2, imagen 2 de 2
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire .
  3. Solio Rocsta LED Replacement, Battery: paso 3, imagen 1 de 1
    • Using the spudger, pry the battery off the back cover.
  4. Solio Rocsta LED Replacement: paso 4, imagen 1 de 1
    • Using a T6 Torx screwdriver, unscrew the 5.66 mm screws attaching the circuit board to the case and flip the circuit board.
  5. Solio Rocsta LED Replacement: paso 5, imagen 1 de 1
    • With the circuit board flipped, locate the battery connector.
    • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
  6. Solio Rocsta LED Replacement, LED: paso 6, imagen 1 de 1
    • Using a T6 Torx screwdriver, unscrew the 5.66 mm screws attaching the circuit board to the case.
  7. Solio Rocsta LED Replacement: paso 7, imagen 1 de 1
    • Flip the circuit board to be able to see where the LEDs are soldered to.
    • With a Soldering Iron, desolder the LEDs’ connectors.
    • For more information on how to solder and desolder connections, please visit this guide.
  8. Solio Rocsta LED Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Gently pry the LEDs using one of the Precision Tweezers.
Conclusión
Una persona más ha completado esta guía.
David Vazquez
Miembro Desde 10/10/17
577 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S13-G13, Cagle Fall 2017 Miembro de USF Tampa, Team S13-G13, Cagle Fall 2017
USFT-CAGLE-F17S13G13
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 121
