Saltar al contenido principal
Solio Rocsta Battery Replacement
Qué necesitas
  1. Solio Rocsta Battery Replacement, Solio Rocsta Top Cover Disassembly: paso 1, imagen 1 de 2 Solio Rocsta Battery Replacement, Solio Rocsta Top Cover Disassembly: paso 1, imagen 2 de 2
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
  2. Solio Rocsta Battery Replacement: paso 2, imagen 1 de 2 Solio Rocsta Battery Replacement: paso 2, imagen 2 de 2
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire .
  3. Solio Rocsta Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Using the spudger, pry the battery off the back cover.
  4. Solio Rocsta Battery Replacement: paso 4, imagen 1 de 1
    • Using a T6 Torx screwdriver, unscrew the 5.66 mm screws attaching the circuit board to the case and flip the circuit board.
  5. Solio Rocsta Battery Replacement: paso 5, imagen 1 de 1
    • With the circuit board flipped, locate the battery connector.
    • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
Conclusión
Una persona más ha completado esta guía.
David Vazquez
Miembro Desde 10/10/17
577 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S13-G13, Cagle Fall 2017 Miembro de USF Tampa, Team S13-G13, Cagle Fall 2017
USFT-CAGLE-F17S13G13
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 242
