Saltar al contenido principal
Solio CLASSIC2 Battery Replacement
Qué necesitas
  1. Solio CLASSIC2 Battery Replacement, Disconnecting the Battery: paso 1, imagen 1 de 1
    • Turn off the device by pressing on the clear power button behind the device.
    • To make sure that it is off, make sure the button is not flashing green.
  2. Solio CLASSIC2 Battery Replacement: paso 2, imagen 1 de 1
    • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
  3. Solio CLASSIC2 Battery Replacement: paso 3, imagen 1 de 3 Solio CLASSIC2 Battery Replacement: paso 3, imagen 2 de 3 Solio CLASSIC2 Battery Replacement: paso 3, imagen 3 de 3
    • Using the plastic opening tools, gently pry open the side of the large panel.
    • Keeping the tool in, slowly slide the tool along the side of the panel.
  4. Solio CLASSIC2 Battery Replacement: paso 4, imagen 1 de 2 Solio CLASSIC2 Battery Replacement: paso 4, imagen 2 de 2
    • Rotate the device 180 degrees.
    • Make sure the opening on other side of the device does not snap closed.
    • Gently slide the plastic opening tool along the side of the panel.
  5. Solio CLASSIC2 Battery Replacement: paso 5, imagen 1 de 2 Solio CLASSIC2 Battery Replacement: paso 5, imagen 2 de 2
    • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
    • Using both hands, slowly pull apart the back panel from the rest of the device.
    • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
  6. Solio CLASSIC2 Battery Replacement: paso 6, imagen 1 de 2 Solio CLASSIC2 Battery Replacement: paso 6, imagen 2 de 2
    • Softly pinch the red and blue wires close to the white connector.
    • To pull the wires out, wiggle them back and forth until the connector is fully out.
  7. Solio CLASSIC2 Battery Replacement, Circuit Board: paso 7, imagen 1 de 1
    • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
  8. Solio CLASSIC2 Battery Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
    • Gently lift the circuit board out of the device using tweezers.
  9. Solio CLASSIC2 Battery Replacement, Battery: paso 9, imagen 1 de 1
    • Remove the two 2mm screws from the battery case.
  10. Solio CLASSIC2 Battery Replacement: paso 10, imagen 1 de 1
    • Gently pull up the battery case out of the tabs and pull the case out.
  11. Solio CLASSIC2 Battery Replacement: paso 11, imagen 1 de 1
    • Gently lift up the battery.
Conclusión
Johnny Tran
Miembro Desde 10/21/13
311 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 4-28, Amido Fall 2013 Miembro de Cal Poly, Team 4-28, Amido Fall 2013
CPSU-AMIDO-F13S4G28
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 1,281
