Herramientas
Partes
Flip lantern upside down and unscrew the 4 phillips head screws on the base and remove the base plate.
To disassemble the main body, grip the lantern so that the front half of the body with the power button on it is in your right hand and the back half with the hand crank is in your left.
Pinch the front half of the body on both sides with your thumb and index finger just below the first extruding rim of the front plate while simultaneously pulling the back half away. This may take some effort to do.
Locate the crank dynamo component. It is mounted on the back plate directly above the battery.
Trace the wires from the dynamo component to the main power board. Pull out the white clip from the socket on the main board. This will sever the electrical connection between the crank dynamo and the rest of the lantern.
Place new crank dynamo where the old one was previously housed on the back plate. Make sure to align screw holes on the dynamo to those on plate.
Replace the four screws holding the dynamo in place.
Attach the wires from the new crank dynamo to the correct area of the main board where the old wires were removed.
