Saltar al contenido principal
Softball Glove String Replacement
Qué necesitas
  1. Softball Glove String Replacement, Softball Glove String: paso 1, imagen 1 de 3 Softball Glove String Replacement, Softball Glove String: paso 1, imagen 2 de 3 Softball Glove String Replacement, Softball Glove String: paso 1, imagen 3 de 3
    • Tie a knot at one end of the string.
  2. Softball Glove String Replacement: paso 2, imagen 1 de 2 Softball Glove String Replacement: paso 2, imagen 2 de 2
    • Put the string through the loop of the leather needle.
  3. Softball Glove String Replacement: paso 3, imagen 1 de 2 Softball Glove String Replacement: paso 3, imagen 2 de 2
    • Push the needle through the first hole on the backside of the pinky finger.
  4. Softball Glove String Replacement: paso 4, imagen 1 de 3 Softball Glove String Replacement: paso 4, imagen 2 de 3 Softball Glove String Replacement: paso 4, imagen 3 de 3
    • Pull the string out of the needle and back the needle out of the hole.
  5. Softball Glove String Replacement: paso 5, imagen 1 de 2 Softball Glove String Replacement: paso 5, imagen 2 de 2
    • Pull the string all the way through and reinsert the string into the needle.
  6. Softball Glove String Replacement: paso 6, imagen 1 de 2 Softball Glove String Replacement: paso 6, imagen 2 de 2
    • Push the needle through the bottom hole on the ring finger.
    • Pull the string out of the needle and all the way through the hole. Back the needle out of the hole.
  7. Softball Glove String Replacement: paso 7, imagen 1 de 3 Softball Glove String Replacement: paso 7, imagen 2 de 3 Softball Glove String Replacement: paso 7, imagen 3 de 3
    • Insert the string back into the needle and push it through the bottom hole on the pinky.
    • Pull the string all the way through and remove it from the needle.
  8. Softball Glove String Replacement: paso 8, imagen 1 de 3 Softball Glove String Replacement: paso 8, imagen 2 de 3 Softball Glove String Replacement: paso 8, imagen 3 de 3
    • Pull the string under the loop, making an X.
  9. Softball Glove String Replacement: paso 9, imagen 1 de 3 Softball Glove String Replacement: paso 9, imagen 2 de 3 Softball Glove String Replacement: paso 9, imagen 3 de 3
    • Put the string through the needle and push the needle though the top hole on the ring finger.
  10. Softball Glove String Replacement: paso 10, imagen 1 de 3 Softball Glove String Replacement: paso 10, imagen 2 de 3 Softball Glove String Replacement: paso 10, imagen 3 de 3
    • Going around the back of the ring finger, insert the string through the top hole on the left side of the ring finger.
    • Pull the string all the way through.
  11. Softball Glove String Replacement: paso 11, imagen 1 de 3 Softball Glove String Replacement: paso 11, imagen 2 de 3 Softball Glove String Replacement: paso 11, imagen 3 de 3
    • Insert the string through the bottom hole on the middle finger.
  12. Softball Glove String Replacement: paso 12, imagen 1 de 2 Softball Glove String Replacement: paso 12, imagen 2 de 2
    • Cross over the backside and insert the string into the bottom hole on the left side of the ring finger.
  13. Softball Glove String Replacement: paso 13, imagen 1 de 3 Softball Glove String Replacement: paso 13, imagen 2 de 3 Softball Glove String Replacement: paso 13, imagen 3 de 3
    • Pull the string under the loop to make an X.
  14. Softball Glove String Replacement: paso 14, imagen 1 de 3 Softball Glove String Replacement: paso 14, imagen 2 de 3 Softball Glove String Replacement: paso 14, imagen 3 de 3
    • Push the string through the top hole on the right side of the middle finger.
  15. Softball Glove String Replacement: paso 15, imagen 1 de 3 Softball Glove String Replacement: paso 15, imagen 2 de 3 Softball Glove String Replacement: paso 15, imagen 3 de 3
    • Going around the back of the middle finger, insert the string into top hole on the right side of the middle finger.
  16. Softball Glove String Replacement: paso 16, imagen 1 de 3 Softball Glove String Replacement: paso 16, imagen 2 de 3 Softball Glove String Replacement: paso 16, imagen 3 de 3
    • Insert the string into the bottom right hole on the pointer finger.
  17. Softball Glove String Replacement: paso 17, imagen 1 de 3 Softball Glove String Replacement: paso 17, imagen 2 de 3 Softball Glove String Replacement: paso 17, imagen 3 de 3
    • On the backside, push the string through the bottom left hole on the middle finger and pull the string all the way through.
  18. Softball Glove String Replacement: paso 18, imagen 1 de 3 Softball Glove String Replacement: paso 18, imagen 2 de 3 Softball Glove String Replacement: paso 18, imagen 3 de 3
  19. Softball Glove String Replacement: paso 19, imagen 1 de 3 Softball Glove String Replacement: paso 19, imagen 2 de 3 Softball Glove String Replacement: paso 19, imagen 3 de 3
    • Insert the string into the top right hole on the pointer finger and pull the string all the way through.
  20. Softball Glove String Replacement: paso 20, imagen 1 de 3 Softball Glove String Replacement: paso 20, imagen 2 de 3 Softball Glove String Replacement: paso 20, imagen 3 de 3
    • Tie the end of the string close to the glove.
    • Cut off the excess string.
Conclusión
To remove a string from a softball glove, repeat these steps in reverse order.
Una persona más ha completado esta guía.
Christina Hart
Miembro Desde 03/23/21
331 Reputación
1 Guía escrita
Equipo
Un comentario
Thank you so much for sharing this guide on softball glove string replacement! Your step-by-step instructions made it easy for me to replace the strings on my old glove and bring it back to life. Your expertise and generosity are truly appreciated!
Juliet Cyrus - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 74
Todo El Tiempo: 896
