Saltar al contenido principal
SodaStream Fountain Jet A200 Spring Replacement
  1. SodaStream Fountain Jet A200 Spring Replacement, removing back cover: paso 1, imagen 1 de 2 SodaStream Fountain Jet A200 Spring Replacement, removing back cover: paso 1, imagen 2 de 2
    • Press in the two gray buttons found on either side, at the top of the machine.
    • Pull back on the cover until it releases from the device and pull the back off.
  2. SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: paso 2, imagen 1 de 2 SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: paso 2, imagen 2 de 2
    • Place your hand under the carbonation button and gently pull up and away from you, towards the back of the machine.
  3. SodaStream Fountain Jet A200 Spring Replacement, spring removal: paso 3, imagen 1 de 2 SodaStream Fountain Jet A200 Spring Replacement, spring removal: paso 3, imagen 2 de 2
    • Remove the spring located under the carbonation button.
    • Replace with the new spring, by lining it up and pushing it down.
Conclusión
5 personas más completaron esta guía.
2 comentarios
Does anyone know where I can get a carbonation button?
draganr@wi.rr.com
draganr - Contestar
Do we know the spring parameters?
Outside Diameter
Inside Diameter
Overall Length
Wire Diameter
Total # of Coils
Active # of Coils
Solid Height
Space between the Coils
John Friedman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 17
Ultimos 30 días: 54
Todo El Tiempo: 9,921
