Saltar al contenido principal
Snowboard Traction Pad Replacement
Qué necesitas
  1. Snowboard Traction Pad Replacement, Traction Pad: paso 1, imagen 1 de 2 Snowboard Traction Pad Replacement, Traction Pad: paso 1, imagen 2 de 2
    • Use a plastic or metal scraper to remove the existing traction pad.
  2. Snowboard Traction Pad Replacement: paso 2, imagen 1 de 3 Snowboard Traction Pad Replacement: paso 2, imagen 2 de 3 Snowboard Traction Pad Replacement: paso 2, imagen 3 de 3
    • If there is any residual adhesive left from the old traction pad, soak it with adhesive remover.
    • Let the adhesive remover sit for a few minutes.
    • Wipe away the residue using a towel and water.
    • Dry the the surface where the new traction pad will be placed.
  3. Snowboard Traction Pad Replacement: paso 3, imagen 1 de 3 Snowboard Traction Pad Replacement: paso 3, imagen 2 de 3 Snowboard Traction Pad Replacement: paso 3, imagen 3 de 3
    • Peel the back off of the new traction pad to reveal the adhesive.
    • When placed, the traction pad should be about an inch away from the rear binding.
    • To avoid creating air bubbles, start with one corner of the pad and roll the rest down.
    • Press down firmly to help it stick to the board and remove any air bubbles that may have occurred.
    • Give the adhesive a minimum of 12 hours to dry before use.
Linea de Meta
Jacob Garcia
Miembro Desde 01/13/14
101 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 17-4, Forte Winter 2014 Miembro de Cal Poly, Team 17-4, Forte Winter 2014
CPSU-FORTE-W14S17G4
5 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 3,606
