Saltar al contenido principal
Snow Blower Shear Bolt Replacement
Qué necesitas
  1. Snow Blower Shear Bolt Replacement, Locate new shear bolt: paso 1, imagen 1 de 1
    • The new shear bolt is stored on the top of the auger discharge
  2. Snow Blower Shear Bolt Replacement, Remove the old shear bolt: paso 2, imagen 1 de 3 Snow Blower Shear Bolt Replacement, Remove the old shear bolt: paso 2, imagen 2 de 3 Snow Blower Shear Bolt Replacement, Remove the old shear bolt: paso 2, imagen 3 de 3
    • The shear bolt attaches the auger to the shaft
    • The shear bolt is designed to break preventing damage to the auger and shaft if an hard object is pulled in
    • Locate the side with the missing shear bolt
    • The left side is missing
    • This auger will spin freely on this side
    • Rotate the auger to find where the bolt is on the shaft
  3. Snow Blower Shear Bolt Replacement: paso 3, imagen 1 de 2 Snow Blower Shear Bolt Replacement: paso 3, imagen 2 de 2
    • Use the new shear bolt to push the old broken bolt out of the shaft
    • It should fall out and look like this
  4. Snow Blower Shear Bolt Replacement: paso 4, imagen 1 de 2 Snow Blower Shear Bolt Replacement: paso 4, imagen 2 de 2
    • With the new bolt in place from pushing the old bolt out add a nut
    • Hand tighten
  5. Snow Blower Shear Bolt Replacement: paso 5, imagen 1 de 2 Snow Blower Shear Bolt Replacement: paso 5, imagen 2 de 2
    • Using two 7/16" wrenches tighten the nut on the bolt
    • Do not over tighten
    • Congratulations, both shear bolts have been replaced
Conclusión
2 personas más completaron esta guía.
Jacob Rattray
Miembro Desde 05/11/18
263 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 1,663
