Introducción
The SIM card is a removable storage component inside of the phone. The card stores phone numbers and other important information to the user.
Qué necesitas
Turn off the phone to prevent data loss.
Press and slide the battery out to remove it.
Use the tweezers,if needed, to grasp the SIM card for removal. Apply a slight pulling tension and remove it from under the tabs as shown.
To reinsert the SIM card or a new SIM card, position the card in the same orientation seen in the figure with the brass connections facing the phone while using thumb to apply a slight force until the card rest inside of the recessed holder. Make sure the brass contacts of the card and phone connect. Then follow the steps in reverse order to reassemble phone.
