Introducción
The charging port is the component of the phone that allows the charger to be connected to the phone in order to charge the internal rechargeable battery.
Qué necesitas
Turn off the phone to prevent data loss.
Press and slide the battery out to remove it.
Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
Separate the front case from the back case.
Remove the metal bumper from the front case’s perimeter.
Separate the circuit board from the inside of the back case by prying between them with the opening tool.
The last picture is a view of the back of the circuit board.
Insert new charging port, and to reassemble your device, follow these instructions in reverse order.
