Saltar al contenido principal
Smart Tweezers and LCR-Reader LCR-meter Screen Replacement
Qué necesitas
  1. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Opening the device: paso 1, imagen 1 de 2 Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Opening the device: paso 1, imagen 2 de 2
    • Start by removing the 4 screws in the back of the device using a size 00 Philips screw driver.
  2. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Replacing the screen: paso 2, imagen 1 de 2 Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Replacing the screen: paso 2, imagen 2 de 2
    • Gently open the zif connector that holds the screen.
    • Insert the replacement screen, and close the zif
  3. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Closing the device: paso 3, imagen 1 de 1
    • When closing the housing, make sure the screen fits into the rectangle on the top.
    • If the screen is not in this rectangle, it may become damaged when the screws are tightened
    • Hold the screen in place from below; line up the button's edge of the top housing to line up with the bottom housing. Slide your finger out as you bring the top and bottom housings to meet.
    • Replace the 4 Philips screws in the back.
Linea de Meta
Una persona más ha completado esta guía.
brittany
Miembro Desde 07/16/12
234 Reputación
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 553
