Saltar al contenido principal
Smart Parts Ion Macroline Replacement
  1. Smart Parts Ion Macroline Replacement, Hopper and the Air Tank: paso 1, imagen 1 de 3 Smart Parts Ion Macroline Replacement, Hopper and the Air Tank: paso 1, imagen 2 de 3 Smart Parts Ion Macroline Replacement, Hopper and the Air Tank: paso 1, imagen 3 de 3
    • Remove the air tank by rotating it counterclockwise.
    • Do not pull the trigger or jostle the gun, there will still be pressurized air inside the gun that could be expelled and cause bodily harm if injected into eyes and/or skin.
    • The pressure gauge will indicate the leftover air in the gun.
  2. Smart Parts Ion Macroline Replacement: paso 2, imagen 1 de 2 Smart Parts Ion Macroline Replacement: paso 2, imagen 2 de 2
    • Remove the hopper by pulling it out of the feed tube, located on the top of the body. The hopper should easily come off when pulled straight up.
  3. Smart Parts Ion Macroline Replacement, Smart Parts Ion De-Gassing: paso 3, imagen 1 de 1
    • Turn the gun on by pressing the power button until the red light blinks.
    • Turn vision mode off by pressing the power button again.
    • Red light should be flashing in a double blink sequence.
  4. Smart Parts Ion Macroline Replacement: paso 4, imagen 1 de 1
    • Pull the trigger to release the air in the gun.
    • Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels, causing embolisms. To avoid this, make sure to point the gun in a safe direction when pulling the trigger because air will be released from the gun.
  5. Smart Parts Ion Macroline Replacement, Macroline: paso 5, imagen 1 de 3 Smart Parts Ion Macroline Replacement, Macroline: paso 5, imagen 2 de 3 Smart Parts Ion Macroline Replacement, Macroline: paso 5, imagen 3 de 3
    • Push the metal fitting inwards and pull out the black tube. Repeat on the other side.
Conclusión
Shane Villalpando
Miembro Desde 02/02/15
1,031 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 8-42, Amido Winter 2015 Miembro de Cal Poly, Team 8-42, Amido Winter 2015
CPSU-AMIDO-W15S8G42
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 1,545
