Saltar al contenido principal
  1. Remove the air tank by rotating it counterclockwise. Do not pull the trigger or jostle the gun, there will still be pressurized air inside the gun that could be expelled and cause bodily harm if injected into eyes and/or skin. The pressure gauge will indicate the leftover air in the gun.
    • Remove the air tank by rotating it counterclockwise.
    • Do not pull the trigger or jostle the gun, there will still be pressurized air inside the gun that could be expelled and cause bodily harm if injected into eyes and/or skin.
    • The pressure gauge will indicate the leftover air in the gun.
  2. Remove the hopper by pulling it out of the feed tube, located on the top of the body. The hopper should easily come off when pulled straight up. Remove the hopper by pulling it out of the feed tube, located on the top of the body. The hopper should easily come off when pulled straight up.
    • Remove the hopper by pulling it out of the feed tube, located on the top of the body. The hopper should easily come off when pulled straight up.
Conclusión
Shane Villalpando
Miembro Desde 02/02/15
1,022 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 8-42, Amido Winter 2015 Miembro de Cal Poly, Team 8-42, Amido Winter 2015
CPSU-AMIDO-W15S8G42
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 36
