Saltar al contenido principal
Small Engine Recoil Starter Replacement
Qué necesitas
  1. Small Engine Recoil Starter Replacement, Recoil Starter: paso 1, imagen 1 de 1
    • To begin the repair remove the protective casing. (This removal may vary with different lawnmowers.)
  2. Small Engine Recoil Starter Replacement: paso 2, imagen 1 de 1
    • Locate the recoil housing cap.
  3. Small Engine Recoil Starter Replacement: paso 3, imagen 1 de 1
    • Carefully remove the housing cap. (Removal may vary)
  4. Small Engine Recoil Starter Replacement: paso 4, imagen 1 de 1
    • After removing the recoil, unscrew the cap that holds the pulley to the recoil starter housing.
  5. Small Engine Recoil Starter Replacement: paso 5, imagen 1 de 1
    • Untie the knot in the rope and slide it out of the housing.
  6. Small Engine Recoil Starter Replacement: paso 6, imagen 1 de 1
    • With this particular model there is a middle lock piece. Use a socket wrench to unscrew and release the coil.
  7. Small Engine Recoil Starter Replacement: paso 7, imagen 1 de 1
    • Once unscrewed, remove the metal piece which releases the tension on the coil.
  8. Small Engine Recoil Starter Replacement: paso 8, imagen 1 de 1
    • At this point add the new coil to the housing base. Snap the coil into position where the old on was.
Conclusión
5 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 49
Todo El Tiempo: 2,782
