Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
The purpose of this guide is to show the steps necessary to replace the faulty DC power connector.
  1. Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
    • Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
  2. The Slingbox has four black 5mm screws, one on each corner of the case. Remove the four black 5mm screws using the PH1 screwdriver. Gently pull and separate the two case covers.
    • The Slingbox has four black 5mm screws, one on each corner of the case.
    • Remove the four black 5mm screws using the PH1 screwdriver.
    • Gently pull and separate the two case covers.
  3. El kit de herramientas esencial
    Las herramientas más útiles en nuestro kit más compacto.
    Compra ahora
    Compra ahora
  4. The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox. Remove the five silver screws on the motherboard using the PH1 screwdriver. Gently slide and separate the motherboard from the base.
    • The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox.
    • Remove the five silver screws on the motherboard using the PH1 screwdriver.
    • Gently slide and separate the motherboard from the base.
  5. Do not touch the heated tip of the soldering iron.
    • Do not touch the heated tip of the soldering iron.
    • Check this guide out to learn how to use a soldering iron.
    • Desolder all three lead prongs.
    • Gently pull the DC power connector from the motherboard.
Conclusión
To reassemble your device, follow the instructions in reverse order.
Nitin Muralidhar
Miembro Desde 18/07/16
222 Reputación
2 Guías creadas
Equipo
IUPUI, Team 2-2, Harley SU 2016 Miembro de IUPUI, Team 2-2, Harley SU 2016
IUPUI-HARLEY-SU16S2G2
5 Miembros
2 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 202
