Saltar al contenido principal
Skytex SP728 Speakers Replacement
Qué necesitas
  1. Skytex SP728 Speakers Replacement, Case: paso 1, imagen 1 de 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Speakers Replacement: paso 2, imagen 1 de 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Speakers Replacement: paso 3, imagen 1 de 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Speakers Replacement: paso 4, imagen 1 de 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Speakers Replacement, Speakers: paso 5, imagen 1 de 1
    • Identify the connection location of the wires from the speakers.
  6. Skytex SP728 Speakers Replacement: paso 6, imagen 1 de 1
    • Use a soldering iron to remove the speaker wires from the circuit board
  7. Skytex SP728 Speakers Replacement: paso 7, imagen 1 de 1
    • Solder the new speakers to the correct location, making sure the red wire goes to the + and the black wire goes to the -.
Conclusión
Una persona más ha completado esta guía.
Chris Nelson
Miembro Desde 01/21/15
213 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 5-1, Brown Winter 2015 Miembro de USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 102
