Saltar al contenido principal
Skytex SP728 Antenna Replacement
Qué necesitas
  1. Skytex SP728 Antenna Replacement, Case: paso 1, imagen 1 de 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Antenna Replacement: paso 2, imagen 1 de 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Antenna Replacement: paso 3, imagen 1 de 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Antenna Replacement: paso 4, imagen 1 de 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Antenna Replacement, Antenna: paso 5, imagen 1 de 1
    • Remove the case and open the device
  6. Skytex SP728 Antenna Replacement: paso 6, imagen 1 de 1
    • Remove the black tapes
  7. Skytex SP728 Antenna Replacement: paso 7, imagen 1 de 1
    • Use the soldering station and remove soldered connections to the antenna wires.
    • Now replace the antenna.
    • Follow the link below for additional soldering information "https://www.ifixit.com/Guide/How+To+Sold...
Conclusión
Una persona más ha completado esta guía.
Galika Adhikari
Miembro Desde 01/21/15
248 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 5-1, Brown Winter 2015 Miembro de USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 105
