Saltar al contenido principal
Sky 6.0Q Top Motherboard Replacement
Qué necesitas
  1. Sky 6.0Q Top Motherboard Replacement, Top Motherboard: paso 1, imagen 1 de 1
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Top Motherboard Replacement: paso 2, imagen 1 de 1
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Top Motherboard Replacement: paso 3, imagen 1 de 2 Sky 6.0Q Top Motherboard Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Top Motherboard Replacement: paso 4, imagen 1 de 1
    • Use the spudger disconnect the gold cord extending from the battery to the top electronic board.
  5. Sky 6.0Q Top Motherboard Replacement: paso 5, imagen 1 de 3 Sky 6.0Q Top Motherboard Replacement: paso 5, imagen 2 de 3 Sky 6.0Q Top Motherboard Replacement: paso 5, imagen 3 de 3
    • Use the nylon spudger to help pry up the three top motherboard attachments.
    • See all three pictures for three attachment locations.
    • To reattach top motherboard connections gently press piece back in place.
  6. Sky 6.0Q Top Motherboard Replacement: paso 6, imagen 1 de 1
    • Use the #00 Phillips screwdriver to remove the three 3 mm screws attaching the top motherboard.
  7. Sky 6.0Q Top Motherboard Replacement: paso 7, imagen 1 de 1
    • Once the screws are removed, gently lift the top motherboard and replace.
Conclusión
Una persona más ha completado esta guía.
Monica Difato
Miembro Desde 11/06/18
429 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G3, Hovde Fall 2018 Miembro de IUPUI, Team S1-G3, Hovde Fall 2018
IUPUI-HOVDE-F18S1G3
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 400
