Saltar al contenido principal
Sky 6.0Q Battery Replacement
Qué necesitas
  1. Sky 6.0Q Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Battery Replacement: paso 2, imagen 1 de 1
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Battery Replacement: paso 3, imagen 1 de 2 Sky 6.0Q Battery Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Battery Replacement: paso 4, imagen 1 de 1
    • Disconnect the gold cord extending from the battery to the top electronic board.
    • Use the nylon spudger to help pry up the battery attachment.
    • To reattach the gold cord and battery attachment connection, gently press piece back in place.
  5. Sky 6.0Q Battery Replacement: paso 5, imagen 1 de 1
    • Use the nylon spudger to get underneath the battery and separate it from the phone back.
    • There is a white, milky adhesive so be careful to not rip or puncture the battery during removal.
  6. Sky 6.0Q Battery Replacement: paso 6, imagen 1 de 1
    • Once separated, remove battery and replace with a new battery.
Conclusión
2 personas más completaron esta guía.
Monica Difato
Miembro Desde 11/06/18
429 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G3, Hovde Fall 2018 Miembro de IUPUI, Team S1-G3, Hovde Fall 2018
IUPUI-HOVDE-F18S1G3
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 56
Todo El Tiempo: 2,303
