Introducción
The wires in headphones are an essential part. If sound is not generating from one speaker, the problem may be from a rip or break in the wires found within the earpiece. This guide shows you how to repair a broken wire inside the earpiece for the Skullcandy UPROCK S5URFZ-390.
Herramientas
Partes
No se especificaron partes.
If a wire is broken, use a soldering iron to reattach it to the speaker.
To learn how to solder, read the Cómo soldar y desoldar conexiones Guide.
After soldering is complete, the wires should look like this.
2 personas más completaron esta guía.
Un Comentario
my jack is broken can i get a whole new wire so i could do soldering or can i use any other wire. if i use any other wire can i connect in btw of old wire coz i removed the jack by cutting the wire from jack or do i have to do soldering from beginning form inside.
