Saltar al contenido principal
Skullcandy Air Raid Motherboard Replacement
Qué necesitas
  1. Skullcandy Air Raid Motherboard Replacement, Rubber Cover: paso 1, imagen 1 de 1
    • Starting with the corners, gently pull the rubber cover off of the device.
  2. Skullcandy Air Raid Motherboard Replacement, Handle: paso 2, imagen 1 de 1
    • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
    • Remove the handle from the device.
  3. Skullcandy Air Raid Motherboard Replacement, Front Plate: paso 3, imagen 1 de 1
    • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
    • One 5mm Phillips screw.
    • One 8mm Phillips screw.
  4. Skullcandy Air Raid Motherboard Replacement: paso 4, imagen 1 de 1
    • Gently pull the sides of the front plate outwards from the device.
    • Pull up on the front plate to remove it from the device.
  5. Skullcandy Air Raid Motherboard Replacement, Speakers: paso 5, imagen 1 de 1
    • Using a #000 Philips Screwdriver, unscrew the four 8 mm Philips screws from each corner of both speakers (eight 8 mm Philips screws total).
  6. Skullcandy Air Raid Motherboard Replacement: paso 6, imagen 1 de 1
    • Using the plastic opening tool, pry around edges of the speaker to loosen glue contact with front plate.
    • If you are unable to loosen glue contact using the plastic opening tool, use a heat gun to assist in removal.
  7. Skullcandy Air Raid Motherboard Replacement: paso 7, imagen 1 de 1
    • Lift the speaker out of the device.
    • Be aware of the connection with the ribbon cable.
    • For reassembly, ensure proper orientation of the cable plug.
  8. Skullcandy Air Raid Motherboard Replacement: paso 8, imagen 1 de 1
    • Firmly pull on the end of ribbon cable to disconnect the speaker from the motherboard.
  9. Skullcandy Air Raid Motherboard Replacement, Control Buttons: paso 9, imagen 1 de 1
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, above and below volume buttons.
  10. Skullcandy Air Raid Motherboard Replacement: paso 10, imagen 1 de 1
    • Lift the button panel.
  11. Skullcandy Air Raid Motherboard Replacement, Button Motherboard: paso 11, imagen 1 de 1
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
  12. Skullcandy Air Raid Motherboard Replacement: paso 12, imagen 1 de 1
    • Using a plastic opening tool, pry the button motherboard to detach it from the device.
    • The button motherboard is connected to a ribbon cable inside the device.
  13. Skullcandy Air Raid Motherboard Replacement, Ribbon Cable: paso 13, imagen 1 de 1
    • Pull the black ribbon cord attachment away from the motherboard.
    • Pull on the cable until it releases from the back of the motherboard.
    • The black attachment is part of the connector, not the blue ribbon cable, so it will not disconnect from the motherboard.
  14. Skullcandy Air Raid Motherboard Replacement, Back panel: paso 14, imagen 1 de 2 Skullcandy Air Raid Motherboard Replacement, Back panel: paso 14, imagen 2 de 2
    • Using a Phillips #00 Precision Screwdriver, unscrew two 8 mm screws.
    • Lift off the back panel.
  15. Skullcandy Air Raid Motherboard Replacement, Battery and USB Port Cables: paso 15, imagen 1 de 1
    • Pull the black piece of the USB port ribbon cable connector away from the motherboard.
    • Pull the ribbon cable out of the connector.
  16. Skullcandy Air Raid Motherboard Replacement: paso 16, imagen 1 de 1
    • Pull the USB power cable away from the motherboard to disconnect it.
    • Pull the battery power cable away from the motherboard to disconnect it.
  17. Skullcandy Air Raid Motherboard Replacement, Motherboard: paso 17, imagen 1 de 1
    • Pull up on the motherboard from both sides.
Conclusión
Un comentario
I need a new motherboard. Front and rear. Can I order one?
Nick Fines - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 1,624
