Saltar al contenido principal
Skullcandy Air Raid Buttons Replacement
Qué necesitas
  1. Skullcandy Air Raid Buttons Replacement, Rubber Cover: paso 1, imagen 1 de 1
    • Starting with the corners, gently pull the rubber cover off of the device.
  2. Skullcandy Air Raid Buttons Replacement, Handle: paso 2, imagen 1 de 1
    • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
    • Remove the handle from the device.
  3. Skullcandy Air Raid Buttons Replacement, Front Plate: paso 3, imagen 1 de 1
    • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
    • One 5mm Phillips screw.
    • One 8mm Phillips screw.
  4. Skullcandy Air Raid Buttons Replacement: paso 4, imagen 1 de 1
    • Gently pull the sides of the front plate outwards from the device.
    • Pull up on the front plate to remove it from the device.
  5. Skullcandy Air Raid Buttons Replacement, Control Buttons: paso 5, imagen 1 de 2 Skullcandy Air Raid Buttons Replacement, Control Buttons: paso 5, imagen 2 de 2
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, specifically above and below the volume buttons.
    • Lift the button panel.
  6. Skullcandy Air Raid Buttons Replacement, Button Motherboard: paso 6, imagen 1 de 1
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
  7. Skullcandy Air Raid Buttons Replacement: paso 7, imagen 1 de 1
    • Using a plastic opening tool, pry up on the button motherboard to detach it from the device.
    • The button motherboard is connected to a ribbon cable inside the device.
  8. Skullcandy Air Raid Buttons Replacement, Ribbon Cable: paso 8, imagen 1 de 1
    • First, pull on the black attachment to disconnect it from the metal piece.
    • Release the cable from the back of the motherboard.
    • The black attachment is a part of the connector, not the blue ribbon cable. It will not disconnect from the motherboard.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 1,315
