Saltar al contenido principal
Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement
Qué necesitas
  1. Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Un-clip Battery: paso 1, imagen 1 de 1
    • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  2. Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Battery: paso 2, imagen 1 de 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Battery: paso 2, imagen 2 de 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Battery: paso 2, imagen 3 de 3
    • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
  3. Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Handle: paso 3, imagen 1 de 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Handle: paso 3, imagen 2 de 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove Handle: paso 3, imagen 3 de 3
    • Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill.
  4. Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove the screw from the chuck sleeve: paso 4, imagen 1 de 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove the screw from the chuck sleeve: paso 4, imagen 2 de 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove the screw from the chuck sleeve: paso 4, imagen 3 de 3
    • The chuck sleeve is held on by a 20mm Phillips #2 screw in the center.This screw is reverse threaded. Insert a Phillips #2 screwdriver and rotate it clockwise to loosen and remove it.
  5. Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove the chuck sleeve: paso 5, imagen 1 de 2 Skil X-Drive 18V Cordless Drill Model No. 2887 Chuck Sleeve Replacement, Remove the chuck sleeve: paso 5, imagen 2 de 2
    • The threaded hole the screw was in is in the shape of a 6-point star. Insert a T40 Torx Key and rotate it clockwise to loosen and remove the chuck sleeve.
Conclusión
Jameson
Miembro Desde 09/23/14
258 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 2-3, Blackwell Fall 2014 Miembro de USF Tampa, Team 2-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G3
5 Miembros
9 Guías creadas
Un comentario
For my drill, the Torx screw had to be rotated *counter-clockwise to remove. I'm not sure if that was an error in step #5 or some drills are different.
Thank you for the location of those screws btw.
"Step 5 — Remove the chuck sleeve
and rotate it *clockwise to loosen and remove
the chuck sleeve."
Joe Bailey - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 1,539
