Saltar al contenido principal
Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement
Qué necesitas
  1. Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Un-clip Battery: paso 1, imagen 1 de 1
    • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  2. Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: paso 2, imagen 1 de 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: paso 2, imagen 2 de 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: paso 2, imagen 3 de 3
    • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
Conclusión
4 personas más completaron esta guía.
Sean
Miembro Desde 09/23/14
282 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 2-3, Blackwell Fall 2014 Miembro de USF Tampa, Team 2-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G3
5 Miembros
9 Guías creadas
5 comentarios
my battery is stuck in the drill any ideas
yonko99 - Contestar
My battery is also stuck. I see no replies. What now?
Bobby Verdier - Contestar
Thank you, it really was easy !!!!!
Betty - Contestar
My battery is stuck too. I read on another forum to use a screwdriver and hammer.
I’m a girl, so don’t take my advice, but wondering if you could you spray it with WD-40 to loosen it up?
Amy Dionne - Contestar
Have you been able to get it out? On mine the button was hard to get all the way down. I used both thumbs and was eventually able to get it down far enough to get it off. I bumped it on my leg to help loosen it. If you use a hammer I would suggest using a rubber mallet so you don’t damage the battery or the drill.
Once it’s off clean up the slides real good, spray some WD40 on them, then wipe off with a rag. That should help prevent it from getting stuck again. I would spray a little WD40 on the button and work it back and forth as well.
Hope this helps
Brian Harrod -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 14
Ultimos 30 días: 91
Todo El Tiempo: 6,312
