Introducción
Has your motor stopped running? Switch it out.
Qué necesitas
On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
Herramienta utilizada en este paso:Tweezers$4.99
For reassembly, remove the orange cap on top using your flathead screwdriver. A bushing should come out with it.
Depress the bushing on bottom using the tweezers. To reach the bushing you will have to put the tweezers through the "Skil" lettering. Insert the motor as it is depressed.
Using the tweezers, place the other bushing back in through the hole in the top. Screw the orange cap back on.
To continue reassembly, simply follow the guide backwards starting at step 2.
