Saltar al contenido principal
Introducción
Has your motor stopped running? Switch it out.
Partes
No se especificaron partes.
  1. On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
    • On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
  2. Pull the front housing apart from the rear. The motor and gears might fall out when you are pulling it apart.
    • Pull the front housing apart from the rear.
    • The motor and gears might fall out when you are pulling it apart.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Remove the gear that is threaded onto the divider. Remove the gear that is threaded onto the divider.
    • Remove the gear that is threaded onto the divider.
  5. Remove the divider from the rear housing. The motor may come out along with the divider.
    • Remove the divider from the rear housing.
    • The motor may come out along with the divider.
  6. Pull out the motor. Pull out the motor.
    • Pull out the motor.
  7. For reassembly, remove the orange cap on top using your flathead screwdriver. A bushing should come out with it. Depress the bushing on bottom using the tweezers. To reach the bushing you will have to put the tweezers through the "Skil" lettering. Insert the motor as it is depressed. Using the tweezers, place the other bushing back in through the hole in the top. Screw the orange cap back on.
    • For reassembly, remove the orange cap on top using your flathead screwdriver. A bushing should come out with it.
    • Depress the bushing on bottom using the tweezers. To reach the bushing you will have to put the tweezers through the "Skil" lettering. Insert the motor as it is depressed.
    • Using the tweezers, place the other bushing back in through the hole in the top. Screw the orange cap back on.
Conclusión
To continue reassembly, simply follow the guide backwards starting at step 2.
Matt
Miembro Desde 10/10/10
365 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 5-17, Maness Fall 2010 Miembro de Cal Poly, Team 5-17, Maness Fall 2010
CPSU-MANESS-F10S5G17
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 6
Todo El Tiempo: 407
