Introducción
After deciding that the motor is functional and the power is indeed reaching the motor in the trigger housing, the motor housing will have to be removed and maybe replaced.
  1. On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
    • On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
  2. Pull the front housing apart from the rear.
    • Pull the front housing apart from the rear.
    • The motor and gears might fall out when you are pulling it apart.
    • Use the socket wrench to remove the 0.5" length screw from the bottom of the handle.
    • Separate the cord from the handle.
    • Remove the inner divider.
    • Remove the two 1" flathead screws located at the top and bottom of the motor housing.
    • Pull the motor housing out.
    • The wires from the trigger housing should follow the motor housing.
    • After you have placed the motor housing back into the drill during reassembly, thread the wires down to the handle using tweezers.
    • Plug the forked wire into the socket at the back of the motor housing using tweezers.
Conclusión
To continue reassembly, simply follow the guide backwards starting at step 2.
Matt
Miembro Desde 10/10/10
365 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 5-17, Maness Fall 2010 Miembro de Cal Poly, Team 5-17, Maness Fall 2010
CPSU-MANESS-F10S5G17
3 Miembros
7 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 5
Todo El Tiempo: 2,648
