Saltar al contenido principal
Introducción
The LED screen is attached to the motherboard inside the casing. This guide will show how to detach the screen from the motherboard for replacement.
  1. Take the iFixit opening tool and place it between the crevice as shown.
    • Take the iFixit opening tool and place it between the crevice as shown.
  2. Apply pressure to the iFixit opening tool, pushing down until the the plastic casing pops off. Apply pressure to the iFixit opening tool, pushing down until the the plastic casing pops off.
    • Apply pressure to the iFixit opening tool, pushing down until the the plastic casing pops off.
  3. Use the Phillips PH00 to remove the three marked screws. Use the Phillips PH00 to remove the three marked screws.
    • Use the Phillips PH00 to remove the three marked screws.
  4. Once the screws have been removed, the motherboard is free to come out. Once the screws have been removed, the motherboard is free to come out. Once the screws have been removed, the motherboard is free to come out.
    • Once the screws have been removed, the motherboard is free to come out.
  5. Remove the plastic case in front of the socket using the spudger. Hold the screen and gently pull in the direction of the cable to separate screen from the socket. Hold the screen and gently pull in the direction of the cable to separate screen from the socket.
    • Remove the plastic case in front of the socket using the spudger.
    • Hold the screen and gently pull in the direction of the cable to separate screen from the socket.
Conclusión
Thomas Zhang
Miembro Desde 17/10/17
107 Reputación
1 Guía escrita
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 75
