Saltar al contenido principal
Introducción
The casing of the device can sometimes crack. This guide will show you how to take apart the device and replace the casing.
Partes
No se especificaron partes.
  1. Take the iFixit opening tool and place it between the back casing and the device as shown.
    • Take the iFixit opening tool and place it between the back casing and the device as shown.
  2. Apply pressure to the iFixit opening tool, pushing down until the the plastic casing pops off. Apply pressure to the iFixit opening tool, pushing down until the the plastic casing pops off.
    • Apply pressure to the iFixit opening tool, pushing down until the the plastic casing pops off.
  3. Kits de Reparación de Android
    A new screen or battery is one kit away.
    Comprar Ahora
    Comprar Ahora
  4. Use the Phillips PH00 screwdriver to remove the three marked screws. Use the Phillips PH00 screwdriver to remove the three marked screws.
    • Use the Phillips PH00 screwdriver to remove the three marked screws.
  5. Remove the buttons from the casing. Remove the buttons from the casing. Remove the buttons from the casing.
    • Remove the buttons from the casing.
  6. Remove the motherboard, and the casing should be free. Remove the motherboard, and the casing should be free.
    • Remove the motherboard, and the casing should be free.
Conclusión
Christina Tao
Miembro Desde 17/10/17
319 Reputación
3 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 115
