Saltar al contenido principal
Sirius Stiletto 2 LCD Display Replacement
Qué necesitas
  1. Sirius Stiletto 2 LCD Display Replacement, Battery: paso 1, imagen 1 de 1
    • From the back of the device, slide the back panel downwards to unlock the panel.
    • Lift the panel up, exposing the battery.
  2. Sirius Stiletto 2 LCD Display Replacement: paso 2, imagen 1 de 2 Sirius Stiletto 2 LCD Display Replacement: paso 2, imagen 2 de 2
    • Pinch the battery from both sides and lift the battery to remove it.
  3. Sirius Stiletto 2 LCD Display Replacement, Front Cover: paso 3, imagen 1 de 1
    • Unscrew the four 6.68mm (1.43mm diameter) Philips #00 screws.
    • If needed, remove the sticker to see the screws
  4. Sirius Stiletto 2 LCD Display Replacement: paso 4, imagen 1 de 2 Sirius Stiletto 2 LCD Display Replacement: paso 4, imagen 2 de 2
    • Start by using a plastic opening tool to loosen the front cover from the sides.
    • Work your way to the bottom of the cover then the top.
    • Carefully pry the front cover off.
  5. Sirius Stiletto 2 LCD Display Replacement, LCD Display: paso 5, imagen 1 de 1
    • Gently lift the latch on the the ribbon cable connector inward (towards the motherboard).
  6. Sirius Stiletto 2 LCD Display Replacement: paso 6, imagen 1 de 2 Sirius Stiletto 2 LCD Display Replacement: paso 6, imagen 2 de 2
    • Carefully grip the screen and pull it away from the ribbon connector located on the motherboard.
  7. Sirius Stiletto 2 LCD Display Replacement: paso 7, imagen 1 de 1
    • LCD display (left).
Conclusión
Una persona más ha completado esta guía.
Benjamin Her
Miembro Desde 01/21/15
555 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 6-6, Brown Winter 2015 Miembro de USF Tampa, Team 6-6, Brown Winter 2015
USFT-BROWN-W15S6G6
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 406
